Precalibrated Position Sensors
March 10, 2008
Frictionless, hermetically sealed
MACRO SENSORS' LP750 position sensors are hermetically sealed, frictionless, and will serve as a long-life replacement for failing potentionmeters in a wide range of industrial position measurement applications. They have no parts that wear out and offer unlimited cycle life and greater performance than a potentionmeter. Unique coil winding configuration and digitally enhanced analog output enable a compact design, making units ideal for use in applications with limited installation space. Available in standard ranges of 4 to 25 inches, and offered in precalibrated loop-powered 4-20 input/output, or a nominal 24V DC input 0 to 10 V DC output.
