High Temperature Vortex Tubes
Dec. 3, 2007
Up to 392 F degrees
EXAIR's high temperature vortex tubes are ideal for spot cooling applications that are located in hot environments up to 392°F and produce cold air temperatures as low as -50°F and have cooling capacities of 135-10,200 Btu/hr. They convert an ordinary supply of compressed air into two streams: one hot, one cold. Made of durable stainless steel that resists wear and corrosion.
