Martech Services Co.
Cleaner/Degreaser
Feb. 10, 2010
Water-based, biodegradable
OIL EATER is an eco-friendly cleaner/degreaser, formulated to eliminate the need for multiple cleaning solutions. Non-corrosive, no-toxic, and non-flammable, the low VOC cleaner cuts through oil, grease, carbon, sludge, and dirt, encapsulating them into a solution that rinses off easily and leaves no residues. It is effective on equipment, shafts, bearings, housings, tools, concrete floors, walls, and other surfaces. It can also be used in parts washers and pressure washing systems.
