AMERICAN REFINING GROUP'S Penn Grade RP 150 rustproofing oil is designed to protect against rust and corrosion of metal surfaces under mildly corrosive indoor conditions. Its unique water displacement and fingerprint neutralizing properties are ideal for parts in process. The solvent provides ease of application, evaporating into a thin, highly protective oil film adhering to the metal, protecting the surface. Applied through brushing, spraying, or dipping.
