Fork Lift Vacuum Attachment
Feb. 28, 2008
ANVER’S fork lift vacuum attachment is a detachable vacuum lifter that is mounted on a chassis that slides onto standard 26-in. forks and incorporates 16 spring-assisted vacuum pads, depending on the configuration. Designed to let one operator ...
ANVER’S fork lift vacuum attachment is a detachable vacuum lifter that is mounted on a chassis that slides onto standard 26-in. forks and incorporates 16 spring-assisted vacuum pads, depending on the configuration. Designed to let one operator securely lift sensitive loads from the top, without hooks, grabs, or slings, this vacuum attachment easily slides over the forks, has a remote pendant control, and is powered by a low-maintenance 12 V gel battery. Features built-in parking stands to protect the rubber suction pads when not in use, and can be charged in a 115 VAC outlet and doubles as a hoist-operator lifter.
www.anver.com
