Arc Flash-Rated Height Safety
Breathable-Air Combo System
Pellet-Extrusion Printer for Prototypes
High-Speed Waterblasting
Bulk Bag Fillers
EXAIR’s new 110-gallon, heavy-duty HEPA Vac is a powerful, HEPA-quality industrial vacuum cleaner. The higher-capacity drum means that fewer drum changes will be required during clean-up. The heavy-duty HEPA Vac is designed to move more material with less wear. It has been engineered to filter contaminants to HEPA requirements in dusty environments requiring frequent cleaning.
It is extremely quiet at 82 dBA (half the noise of electric vacuums), making it suitable for a wide variety of environments.
An economical, easily maintained pre-filter stops larger particles, while the HEPA filter handles the smaller matter. All filters are tested for minimum 99.97% filtration at the 0.3 micron level to meet HEPA standards in strict accordance to IEST-RP-CC-007.
The Premium Heavy Duty HEPA Vac System comes complete with the Heavy Duty Dry Vac, lever lock drum lid, shutoff valve, pre-filter, HEPA filter, 10-ft. (3 m) static resistant hose, hose hanger, 1/2 NPT quick connects coupling, 20-ft (6 m) compressed air hose, pressure gauge, heavy duty aluminum tools, tool holder, drum dolly and 110 gallon drum.
OSHA and CE Compliant, the package is offered with a five-year warranty.
