The new E4400 is a portable flue gas analyzer designed for emissions monitoring and maintenance and tuning of combustion processes
Hand-Held Combustion Gas/Emissions Analyzer
April 13, 2014
Field-replaceable, pre-calibrated gas sensors CO auto-range measurements up to 50,000 ppm
The new E INSTRUMENTS INTERNATIONAL E4400 is a portable flue gas analyzer designed for emissions monitoring, and maintenance and tuning of combustion processes. Its rugged design and “true NOx” capability make the E4400 ideal for industrial analysis of furnaces, boilers, and other combustion processes.
Up to four gas sensors, for oxygen, carbon monoxide, nitrous oxide, nitrogen dioxide, sulfur dioxide, and hydrocarbons. Also, it has a built-in printer.
The device includes both field-replaceable and pre-calibrated gas sensors. The dilution pump for CO will complete auto-range measurements up to 50,000 ppm.
The E4400 is capable of measuring both low NOx and “true NOx.” It’s capable of completing both temperature and pressure measurements.
The metal hose connectors are described as “unbreakable.” A rechargeable lithium ion battery pack is included. The internal data memory is capable of conducting 900 tests.
The E4400 is provided with software that is both USB and Bluetooth communication.
Visit www.E-Inst.com
