FEIN Power Tools Inc. offers the Slugger GXE – a fast and versatile deburring machine equipped with a wide range of brushes, useful for deburring as well as finishing touches on numerous product types. For safety, it has an eye shield, integrated circuit breaker for motor protection and emergency safety-stop switch.
For convenience and timesaving, it has a tool-free adjustment of the gap between the wire wheel and workpiece table in addition to a height adjustable workpiece support.
The Slugger GXE has a 3-hp motor that operates at 1,800 RPM. Its maximum wheel diameter is 10x2-3/8 in., and it weighs 71 lb. (32 kg).
For stability, there are two steel bases available for floor mounting the GXE deburring machine. The GIXBE base has a dust-extracting feature for efficient air cleaning. It has a spark-resistant collection box for metal chips, or it can be hooked to an external collection system.
The machine base with extraction capability is rated at 370 W, 440 V having a maximum vacuum of 2.65 mbar. Its dimensions are 12x23x27.5 in. (LxWxH) and weighs 128 lb. (58kg).
The GIXS machine base without extraction capability measures 1x10.5x30 in. (LxWxH), and weighs 40 lb (18 kg). The GXE deburring machine also can also be bench-mounted, which will require connection to an external dust collection system.
Visit www.feinus.com
