The HiTScrub QuenchScrubber system
Quench/Scrubber System for Treating High-Temp Emissions
Sept. 18, 2015
Configurable design for cooling hot-gas streams up to 2,600°F, prior to scrubbing Handles 500 to 150,000 cfm Acid vapors, halogens, or particulate are removed
BIONOMIC INDUSTRIES is introducing the Hi-TScrub Quench/Scrubber system for treating contaminants emitted from high temperature sources.  The developer of air-pollution abatement and heat recovery technologies, stated the new system can be configured horizontally or vertically, and uses advanced spray and Venturi gas quenchers to cool corrosive hot-gas streams up to 2,600°F, prior to scrubbing.
Then, acid vapors, halogens, or particulate are removed from the cooled gas with a Bionomic Series 5000 packed tower or Series 7000 Venturi scrubber.
All units are available as "complete" ScrubPac custom skid-mounted systems in sizes to handle gas capacities from 500 through 150,000 cfm. Typical applications include (but are not limited to) contaminants from thermal oxidizers, incinerators, syn-gas production units, calciners, and furnaces.
Bionomic develops and builds industrial systems for controlling air emissions, air pollution, and odor; fume scrubbing and gas scrubbing systems; particulate removal systems; NOx removal systems; and numerous other product recovery and by-product production systems.
Visit www.bionomicind.com
