Direct Contact, Waste Heat Recovery
Aug. 23, 2016
High efficiency, counter-current flow exchanger recovers valuable BTUs to preheat water, heat workspace, or heat transfer fluids Both sensible and latent heat recovered ROI, 1 to 3 years
The QSense Heat Exchanger is offered in a vertical configuration for maximum space savings, and with all necessary system components.
BIONOMIC INDUSTRIES INC., a developer of air-pollution abatement and heat-recovery technologies, introduced the QSense direct contact, waste heat-recovery system.
Designed to recover valuable waste heat BTUs economically from ovens, boilers, kilns, dryers, thermal oxidizers, and incinerators, QSense’s highly efficient counter-current flow exchanger typically provides a full savings payback within one to three years for most applications. Then, the recovered heat can be used to preheat boiler feed water, meet or supplement building space heating requirements, or for heating process heat transfer fluids.
Both sensible and latent heat is recovered for maximum recovery efficiency and, as flue gases are scrubbed to remove any particulate and gaseous contaminants that are present to reduce plant emissions.
The QSense Heat Exchanger is offered in a vertical configuration for maximum space savings, and with all necessary system components. For flue gases containing acid contaminants the unit can be equipped with neutralizing chemical reagents and for particulate laden streams, a pre-scrubber and clog-resistant contactor is available.
Learn more at www.bionomicind.com
