Plibrico refractory materials are applicable for diecasting furnaces reverberatory furnaces round tops as well as troughs launders and ladles
Castable Refactories, Gunning Mixes for Aluminum Processing
Feb. 21, 2017
Designed to withstand the environments in all aluminum furnaces and transfer equipment Non-wetting refractories Aluminum-resistant castables Phosphate-bonded castables, gun mixes
PLIBRICO COMPANY LLC offers castable refractories and gun mixes for aluminum processing. From non-wetting to aluminum-resistant, to phosphate-bonded castable refractories, Plibrico refractories are designed to withstand the environments in all aluminum furnaces — diecasting furnaces, reverberatory furnaces, round tops — as well as transfer equipment including troughs, launders and ladles.
Plibrico was the first to introduce a complete line of non-wetting aluminum contact castable refractories. The Al-Tuff® non-wetting refractories series was designed specifically to provide an effective and economical solution for aluminum applications.
Plibrico also offers Al-Shield castable refractories and gun mixes designed and engineered specifically for high-temperature, aggressive aluminum alloys and contact areas.
Plibrico has phosphate-bonded castables, gun mixes and plastic materials suitable for metal contact and all other areas in an aluminum furnace. Plibrico’s Exo-Set UNO series of castables and gun mixes are single component, “just add water” phosphate-bonded mixes for quick, easy and safe installation.
Plibrico Company LLC researches, manufactures, and installs alumino-silicate and high-alumina monolithic refractories used in various demanding thermal applications. Learn more at www.plibrico.com.
