BROKK, manufacturer of remote-controlled demolition machines, offers the Brokk 800 in two models for use in various industries including metal and cement processing, construction and demolition, mining and tunneling, and nuclear, as well as other specialty applications.
The Brokk 800S has a three-arm system and offers a maximum reach of nearly 30 feet. When equipped with the included MB1000 breaker, the Brokk 800S produces 1,500 feet per pound at the tip of the tool, nearly twice the hitting power of the Brokk 400.
Specially designed with added heat protection, the Brokk 800P is intended for use in more challenging process applications. It includes an extra-durable, heat-protected SB302 hydraulic breaker to work with hot ladles, runners and furnaces. This solid body hammer delivers 450 feet per pound at the tip of the tool. The Brokk 800P features a 360-degree arm rotation design for challenging, precise angles, and offers an impressive reach of 31.5 feet.
While large and powerful, both Brokk 800 models feature a compact design and capacity-to-size ratio as all Brokk units, allowing access into smaller, more restricted spaces.
Powered by a 60-horsepower electric motor, the Brokk 800 offers emissions-free operation, further permitting work in confined areas. Safety is enhanced, thanks to the remote-control box. It allows operation from a safe distance, protecting operators from hazards such as high heat and falling debris.
The weight of the Brokk 800S, excluding equipment, is 24,310 lb., while the Brokk 800P weighs in at 24,838 lb. Both Brokk 800 units are able to carry attachments up to 2,465 pounds, including beam grapples, buckets, drilling equipment and shotcrete units.
Learn more at www.brokk.com
