Latest from Testing/QC
Martech Services Co.
LK Metrology
Spectroline
The OPTILUX 365 works with all oil and waterbased fluorescent dyes yellow white green bright blue yellowgreen blue and red as well as water dyes It produces a bright glow that makes all leaks easier to find and at the same time cutting diagnostic time
Leak Detecting Flashlight
Aug. 27, 2012
Produces a glow that makes leaks easier to find Works with all oil- and water-based fluorescent dyes
The new Spectroline OPTI-LUX 365 is a powerful but compact leak-detection flashlight that provides enhanced UV light for optimal fluorescent dye response. The developer describes it as “ideal for all industrial fluid system applications.”
The OPTI-LUX 365 works with all oil- and water-based fluorescent dyes: OIL-GLO 22 (yellow), OIL-GLO 30 (white), OIL-GLO 33 (green), OIL-GLO 40 (bright blue), OIL-GLO 44 (yellow/green), OIL-GLO 45 (blue) and OIL-GLO 50 (red), as well as WD-801 and WD-802 water dyes. It produces a brilliant glow that makes all leaks easier to find, while cutting diagnostic time. The flashlight even works with difficult-to-fluoresce dirty fluids, the developer emphasized.
The OPTI-LUX 365 is compact, lightweight and more than twice as powerful as most corded, high-intensity UV lamps. “Instant-on” operation enables the flashlight to reach full power immediately, and it provides up to four hours of continuous run-time. The rugged, anodized aluminum lamp body reduces corrosion and will endure years of heavy use.
The flashlight comes complete with a lanyard, belt holster, two rechargeable batteries, smart charging cradle with AC power cord and UV-absorbing spectacles, all conveniently packaged in a padded carrying case.
Visit www.spectroline.com
