Latest from Finishing
VI-CAS MANUFACTURING supplies vacuum cups for ergonomic lifters of all types and sizes: round, rectangular, or oval cups are available from stock for immediate shipment for a variety of lift manufacturers, including Cynergy Ergonomics, Indutrol, and others.
Sizes and types of cups are available to fit virtually any type of vacuum equipment used for lifting, manipulating, or “pick and place” applications. Accessories such as vacuum valves, swivel joints and level compensators can increase the productivity and energy efficiency of lifting systems.
Materials are available to suit most applications, including high-temperature materials.
An online catalog is searchable by cup attributes such as diameter, height, width, and more.
Vi-Cas can quote custom designs from customer-supplied drawings, and will reverse engineer products from vacuum cups that customers will supply.
Vi-Cas manufactures vacuum cups in various shapes, sizes and materials, short or long manufacturing runs, with short turnaround times. On demand delivery is available. In addition to large vacuum cups, Vi-Cas offers micro-cups and bellows, soap cups, grabbers, suction cups, tightening discs, and grippers, as well as accessories including level compensators, swivel joints, vacuum valves and fittings and adaptors to suit any application.
Visit www.vi-cas.com
