The S3160S Sonder has a process chamber that ranges from 60480 l
Protective Gas Chamber Furnaces
Jan. 3, 2014
Inconel muffle for a max. temp to 1150 °C Three-zone atmosphere control Safety package for H2 atmosphere
LINN HIGH THERM GmbH, a manufacturer of industrial and lab furnaces, introduced a new protective gas chamber furnace – the S-3-160-S Sonder — designed with a gastight muffle, for heat treatment processes under protective gas atmosphere up to 1,050°C.
The process chamber ranges from 60-480 l, and according to customer specification.
The system is recommended for soldering and annealing of workpieces, scale-free treatment of sensitive steel grades, debinding and sintering processes, oxidation or surface reduction, pyrolysis, and many more applications, under controlled atmosphere.
A wide selection of options are available for universal application, including an Inconel muffle for a maximum operating temperature up to 1150°C; three-zone atmosphere control; and a gas-feeding, burning-off device with flame oversight capability.
The S-3-160-S is available with a safety package for hydrogen atmosphere operations. It has a gas ventilation system with fast cooling capability.
The package is capable of gas quenching with heat exchanger, and achieves vacuum up to 800°C.
Visit www.linn.de
