Latest from Finishing
ASTECH INC. introduced a new series of manganese-steel flights for replacement parts in shot-blast machines of all designs. Available as cast or fabricated products, both types of these Premium Dura-Flight (PDF) products are engineered for long service life at low cost, according to the Michigan-based specialty manufacturer. It supplies a range of replacement parts for blast-cleaning machines produced by Wheelabrator, Pangborn, BCP, Goff, and others.
Astech also operates a steel foundry that specializes castings for heat-, wear-, and corrosion-resistance. Alloys cast include manganese steel, carbon steel, low alloy steel, stainless steel, tool steels, high-chromium white iron, and many nickel-based alloys.
The PDF products are designed for heavy-duty, low-maintenance service, and to compliment Astech’s Dura-link line. The supplier noted the new flights reportedly would outlast standard, mild steel flights by more than 300%, and in addition to reducing replacement costs they will promote “higher maintenance efficiencies” and reduce machine downtime.
Both cast and fabricated versions are composed of 11-14% “superior grade” abrasion-resistant manganese steel. Both versions are engineered and tested to outperform OEM flights, and can be customized to fit specific needs.
“Our new Premium Dura-Flights are easily installed and are extremely long lasting,” explained Astech president Alan Bukach. “Our expertise as a foundry puts us in an ideal testing environment for all of our shot blast parts. We were so pleased with the results, that we added it to our line.”
In addition to blast parts, Astech supplies foundry filters that lower energy costs and increase baghouse efficiency.
Visit www.astechblast.com
