Dilok Klaisataporn
Antistick and Release Coating
Nov. 22, 2006
DYLON INDUSTRIES Grade AA Ultra Graphite Coat is a new concentrated water-based, very high temperature antistick and release coating. It may be brushed, spray, or dipped on surfaces as hot as 1,000°F. The dried coating is very smooth and slippery ...
DYLON INDUSTRIES Grade AA Ultra Graphite Coat is a new concentrated water-based, very high temperature antistick and release coating. It may be brushed, spray, or dipped on surfaces as hot as 1,000°F. The dried coating is very smooth and slippery with a low coefficient of friction, and a high electrical and thermal conductivity. It will not crack, nor melt and run at any temperature, will not allow dirt to stick to it, and may be buffed to a mirror finish. When no longer needed, it can be removed with cold water.
www.dylon.com
