Diecaster is Rebranding and Investing
Executive Change at Inductotherm
Top Investment Castings of 2024
Automotive Aftermarket Foundry Books SinterCast
Could Cold Plasma Change HPDC?
Smith Foundry Chooses to Shut Down
GOODFELLOW CORP.’s fused-silica is a popular choice of materials for melting vessels due to its thermal and chemical stability: it makes it possible for vessels to be used with a wide range of materials that may be subject to rapid temperature changes during processing.
However, some manufacturing methods may lead to inconsistent vessels, which risk a much-reduced lifetime, or even failure, during the melting process. To overcome these shortcomings, Goodfellow’s high-purity fused silica melting vessels are molded, producing optimal characteristics for demanding melting applications.
Specific features of high-purity molded fused silica melting vessels include:
• Seamless one-piece construction of fully dense material;
• Uniform microstructure with isotropic properties;
• Nonporous, unreactive internal surface for easy removal of melted material;
• High-purity fused silica to minimize the possibility of product contamination;
• Long lifetime of the melting vessel.
Goodfellow offers high-purity molded fused-silica melting vessels in a range of sizes, capacities, and shapes, including square, cylindrical and rectangular. Customized sizes can be produced, with current maximum outer diameter of 635 mm and height of 400 mm.
